When was the last time you cleaned your airfilter?
How often do you clean your reuseable airfilter? 1 member has voted
  1. 1. How often do you clean your reuseable airfilter?
    • Monthly
      0%
      0
    • Every 3 months
      18%
      4
    • Every 6 months
      13%
      3
    • Once a year
      9%
      2
    • You're supposed to clean it?
      59%
      13
Please sign in or register to vote in this poll.
Been meaning to for about 6 weeks (3 sandstorms ago!). Finally did it and the car runs so much better. Knocked about 2 tablespoons of oily grit from the K&N airfilter!!
Seems to be silly re-mapping the car and not clean the airfilter more often, but time is in short supply these days.
Good idea to have a paper filter on hand while the washed filter dries properly before re-oiling....
With the weekend near at hand, might be a good thing to do if it's been a while.
Bas
My green one could do with a clean about now I reckon. I'll see if I can pinch some of my mate's brake & clutch cleaner stuff - Seems to work well on the filter, but is gentle enough to not damage it structurally. :)
Stu did recommend oxy-blue (?) as a good cleaner. The K&N came with instructions not to use brake/clutch cleaner - too harsh.
Bas
I use a solution of washing detergent on my Green.
It's roughly what the original cleaner is and it does a good job. I try and do mine every 3k which is roughly once every 6 weeks.
I have two Green filters, which I use in rotation. The dirty one gets cleaned and re-oiled as soon as it comes out, so the oil has a long time to soak in before the filter is used again.
I also vacuum the cr@p out fairly regularly without changing the filter.
Clean them based on mileage not duration fitted. 20k for my Pipercross filter.
