need some help
come out to my car tonight and some little oink has pushed in the black caps for the roof bars on one side i have tried myself to get them back to how they was i.e flush with the trim with no hole but i cannot do it
has anyone got any tips for doing this or am i going to have to take it to the local dealer and get charged lots of pennys
cheers:thumbup:
two ways of doing it that I can see -
use a pair of sharp needlenose pliers to get a good grip on them and pull out (I managed to get the round rubber stopper out of the hole in the rear door that way)
Failing that - get a sharp screw and screw it into the rubber bits and pull out that way - will need to replace in that case....
HTH
Bas
Is it possible to remove the cap on the other side ?. If so why not use a garage tyre air line to blow the other one out?. You will need two people ,one to collect it,one to apply the air.
They are pretty cheap to buy - I used to have some spares in the garage for when I used the roof rack.
well i managed to kinda fix it it is back up now and smooth so thats fine as i will never use a roof rack on mine
cheers for the help guys
