Anyone know the Vag tool part no. for gearbox oil plug
Want to open up the gearbox oil plug and the plug is deffo a M16 12-point spline but has a protrusion so that you have to use a VAG-specifc tool.
Found a pic, and now the VAG no. - VW #3357
Bas
14627.attach
Just check Draper's site or Sealey - or even Laser tools for availability, I'm just "shooting the breeze" now, but when I tried to buy a M14 spine bit to remove the strut/hub clamping bolt with the Torx (my foot) head, I was only offered this M16 security spine bit - but that's sods law I suppose! I think that you will find that one of these sites will list the typical uses for this size of tool - to give you confidence that you will be ordering the correct bit. By the way, the Laser Tools site can be a bit of a nightmare to navigate arround - you really need to use your imagination quite a bit - but it could be worth trying.
Bas
Basil , where did you get the tool number from ?
A killer of an internet search - found it as a cross reference to commercial tools mid-way down this page: Volkswagen Tools Volkswagen Tool Audi Tools VW Tools VW Tool Special Service ToolsWent down to the local VAG dealer and they told me they don't sell tools. So I took a regular M16 triple-square tool and annealed it, ground the end so that the protrusions are right to the end of the tool and painfully scraped a 5mm central depression using carbide lathe bits (busted 2!). Vanadium steel is really hard, even softened!
Now it should fit the "tamper-proof" plugs. It would have been easier just to dremel down the central part of the plugs themselves, but I would like to get the proper tool eventually.....
GB on the proper tool anyone?
Bas
sigh, it can be difficult finding stuff when you really need it out here sometimes.....
The modded M16 bit works fine btw....
  • 2 months later...
Thanks for the info. Is it the same as the draper version part number 63476 (HDPK1)
in the draper catalogue??
Thanks for all your input . I will order the draper one as its the same size .
now just got to wait for it to stop raining tso i can do the job. well may be it will stop raining by the end of the year!!!!!!!!!!!!:):thumbup:
  • 1 year later...
thread from the dead :o
