Octavia Elegance Estate pd130 and vrs suspension
Will the VRS estate suspension go straight on the Elegance PD130 Estate? As diesels tend to be a heavier engine than a petrol should I be worried about anything?
Yes, be very worried. The front of the car will be way to low due to the weight of the diesel engine. Rear will be fine though, not the front.
Not such a good plan then, doh!
Is the Pd130 that much more heavy than the 1.8t ? Anyone got the weight figures ?
What does a vRS combi weight compared to an Pd130 Elegance ?
elegance 1455kg
vrs 1390kg
Weights supplied by parkers. And I guess most of the extra weight will be at the front.:thumbdwn:
Ahh well, Guess I will have to save for a different kit to lower the car. Shame really, after having a vrs I like the ride and it's difficult to know which lowering kit togo for without being able to test it day to day before you buy.
Don't just go by what you read on the forum mate. Give someone like awesome or jabba a call.
diesel block is cast iron. It will weigh much more than a petrol engine, and you will need beefier front springs. You might want to look into offerings from eibach, et.al, who will do tailored springs kits for that car. :)
I'd be interested to see how much more uprated PD130 springs are compared to vRS.
I spoke to JBS on the weekend and they recommend Koni Dampers with Eibach Springs. Which after looking around is going to cost me around
I know what you mean.
Why not join the FSD group buy instead.
I've seen that. It's a long way for me to travel and I was hoping todo it for cheaper to get it done sooner. But it looks like the suspension will have to wait. It feels like the clutch is slipping in 6th when the rpm is low and i put my foot down.
TBH i know the elegance suspension is at best cr*p having driven an elegance TDI, but the FSD/eibach or just FSD wouldnt' cost much more than doing VRS suspension and probably less bearing in mind how much you have to change.
That plus the VRS stuff is meant for a car of a lesser weight as mentioned above.
BTW if the clutch is slipping do it sooner rather than later of you run the risk of knackering your DMF I am told :(
What's the dmf?
I had VRS suspension on my 1.8T elegance estate and the rear sat a little too low due to the extra rear weight. I noticed it because I knew there was a difference but generally, it just looked like there was something heavy in the boot - all the time.
Wouldnt do it again if I had another.
Dual Ma ss Flywheel which generally translates to +++
I was told the TDI 110 and TDI PD 130 had a DMF by the dealer I used at the time.
