tyres
How many miles should you get out of a front set of Dunlops 3000?
mine lasted 15k is that good ?
Should I replace with the same again or are Khumas any good or Klaber? :confused:
My fronts had 4 mm on them when i got the car serviced on Saturday, the rears had 5mm. This is with 9500 on the clock.
Tyres have now been swapped front to rear so i expect at least 15k out of them, possibly more..
It depends how you drive.
I managed 23k out of the fronts, but then I do a lot of motorway miles. I did find the edges wore out before the centre though
That will be from running them slightly soft
My fronts had 4 mm on them when i got the car serviced on Saturday' date=' the rears had 5mm. This is with 9500 on the clock.
It depends how you drive.[/quote']
Geoff , I think you may well be looking at some new tyres after 24th April ;)
My fronts lasted 11K miles ,this was after a Northern Meet , a National Meet and an RPM tour .........Track is hard on tyres , depending on how you drive !
Pete...i get my track tyres on saturday, remember ;)
AH ! yes ..............how could I forget ..............you b****** !
:rofl:
I ran them at 32psi on the front, and 33 rear. The rears never wore out, but had a puncture in both tyres in the same week!
Might also be worth getting the tracking/4 wheel alignment checked as this could be a possible cause too...
Chris
  • 2 years later...
the best tyres that my ocy ran were Goodyear. But now i have got rid of the car and now running a Seat Leon type R
