Throttle body alignment??????
Hello i'm thinking of doing the throttle body alignment with my laptop and vag com but I dont know if I really need to do it .
The car has remapped by APR and I myself have fitted a carbonio air filter so I have disconnected the battery to do this and then did this again recently to check the security of the air filter .
So the question is do I need to align the throttle body or not?
Any help on this would be great!! Cheers Scott.
Throttle Body Alignment (TBA) - Ross-Tech Wiki
Some examples of reasons to perform a TBA:
The vehicle's battery has been disconnected and re-connected
The ECU has been removed and reinstalled
The Throttle Body has been cleaned or removed and reinstalled
The Accelerator Pedal has been removed and reinstalled
Ok, now you have me concerned. I chucked a new battery on the other day. Do I need to reset the throttle bodies? The car runs ok, does seem a little lacking in the ooomph dept but that could just be me. Can I do it without vag com if I need to do it?
@Scottie - Just do it. It takes seconds... :rolleyes:
Timo, no, you can't do it without VAGCom, although it used to be believed that you could.
If the car is running is this something that does need to be done, or would it be really noticable should it need doing. As was discussed on one of the vwvortex articles, this can't be something that needs doing all the time, as dealers would be flooded with requests for everytime someone did a bit of DIY. Good money spinner but impractical.
Ok I used Vag-com and realigned the throttle body and I have got to admit it made a hell of a difference , so much so that the girlfriend nearly went straight across a roundabout instead of round it :rofl: .
So to anyone thinking of doing this or has disconnected their battery recently my advise is DO IT!!!! You will notice the difference .
ahh sweet
how hard is it to remove & clean the throttle body?
ahh sweet
Very easy it four 5 or 6 mm allen bolts holding it on theres a gasket you will need as well costs about 50p
so air filter assy off, then its easy to get at?
cheers for the quick reply btw :)
correction gasket cost me
15114.attachHere 's a picture of someone's octy of the site i don't remember who's but i'm sure they won't mind the throttle body is circled
It's steevie wonders thanks steve
ahh ok. Bit of a noob tbh. first octy.
people like lummox etc are such an asset to this briskoda. never seen such great help on a car forum. its superb.
Tell me again why realigning the throttle body makes any difference? what exactly does it do?
I have had my throttle off to clean and have removed battery several times but the car still ran as it should after.
Last night i aligned my throttle body with program called vwtool.The only difference i can see is the idle is just a touch faster.
I think you would have known if you needed to do it really the car would run like 5hite
Think of it as a calibration, telling the ECU the exact position of the flap.
I had another run today.The car seemed to pull quite abit better through the gears.:rofl:
I just did a Throttle Body Alignment and the go pedal now feels better supplying the power. Before it didnt seem to do much till i had pushed it down a bit, but now its instant.
Thats the only ay i can explain it.:thumbup:
I can't remember if i had the battery disconnected to put my stereo in, but it will be to install the carbonio CAI i'm about to order. Any one in edinburgh area with vagcom? plus i was reading somthing about reseting throttle body by opening drivers door and bonnet then turning on the ignish but not starting the engine? sounds a bit strange to me.
