New gauge
Here's my boost gauge :D . Got the electrics plumed in, just waiting for a friend to help with linking into a vaccum pipe. Doesn't look too bad - what does everyone think?
A close up.
As the driver would see it
nice what make is it???????
judging by the logo on the face - AutoGauge ;)
Night time
How did you stick it to the dash?
Cut and drilled a 90 degree piece of metal to fit and stuck it down with velcro, didnt want to start drilling holes in my pride and joy!!
Here's my boots gauge :D .
So when are you fitting a BOOST gauge?
Sorry couldn't resist,very nice installation though, I want one now!
Cheers,
Steve
Haha, edited now. Had a few too many when i wrote this i think.lol
Good thinking.Does anybody know what a standard vrs boost pressure reaches :confused:
yea .5 bar........sorry the logo was a Give away!!!
thought it was .7 bar
standard 180bhp vRS makes approx. 0.7bar boost
really??? learn somthing new Every day!
They peak at 10 psi and hold 7, by the way I have an Autometer 30psi (52mm) boost gauge up for grabs if anyones interested
well mine is standard and holds between 0.65 and 0.7 bar (9.5-10psi) depending on conditions, air temperature etc. I've not taken much notice of peak values.
These are from readings of live data from the management system, so not based on a shonky boost gauge that could be reading wrong.. :)
Thought boost gauges were more accurate then vag com for readings
well mine peaks up to about 10 psi and holds about 7-8 psi. depending what mood the car is in!!!!
as for accuracy. the gauge is only as accurate as it was set up during manufacture. if nothing else the dial behind the needle could have twisted around slightly giving all sorts of readings. all they do is give you an idea what its boosting at. do tuners watch the gauge that you have plumbed. i dont think so!!!
