central locking
hi can anyone tell me does the felicia r reg have a central locking relay and where is it if there is one ive looked in the manual and nothing noted?????????
anyone
I don't know if you have a haynes manual or not - I have checked the fuse box details - fuse number 16 controls the Central locking - number 16 counting from left of the fuse board (located under the glovebox)
thanks the fuse is intact but still have no central locking dont know what else it could be?????
Remote control or key activated? If key, only driver's door or both fronts?
i got all 4 on the key??
found the relay its behind the dash
if anyone is interested lol
where about ?
rite behind the clocks on the right hand side a bugger to get too
I think you're at cross-purposes with me. I was asking if the central locking was a remote control system, or only worked throught the door locks. If it was the door locks, was it driever's door only, or both?
Not that it matters now anyway, since the problem was elsewhere.
the key unlocks all 4 doors by using the key in either front door
was the problem the relay?
yes it was the relay that was the problem thanks for all your comments
