1.4 MPI 2000 Sluggish + Crap MPG
Glad you got the thermostat sorted.:thumbup:
I dont know what over all MPG you should get but anywhere from 250-300 to a tank full driving with vigor. (read giving it some beans)
I tend to change up between 3-4 K keeping it in the power band (LOL!!)
does anyone know what the specs say URBAN MIXED and MOTORWAY are?.
  • Replies 50
  • Views 5.1k
MR KLF,
Argh I see yes both sort of!
I see what they are doing but there not real world.
done on a rolling road no wind resistance unless that some how is calculated in.
You're right, they don't (AFAIK) take any account of wind resistance, or indeed road surface quality, gradient, altitiude etc. etc. But the key is repeatability. If car X is tested under the same lab conditions as car Y, then the difference in their relative fuel efficiencies should be correct. So you wouldn't expect to match the official figures for either car, but they ought to be out by the same percentage if everything else is the same.
Hope that makes sense!
28.8mpg round town on the second link and I was getting 26mpg before the thermostat was replaced.
Hello Fabia1.4. I find that the fuel gauge needle is not a good indicator as it stays put then drops quickly after the half full mark. It's better re my petrol budget to gauge cost per mile over two or three weeks of similar journeys. One way is to fill the car up to full and not refill till the light comes on each time. After having worked it out, I only fill to half full as otherwise carrying unnecessary weight from the fuel itself. :)
Mo
Indeed you get more in the first half of a tank then the second half.
I normally put a full tank in on pay day then work out how much I have used roughly and then top up with enough to get me through the next couple of weeks to next payday normally about anohter
...it's because the fuel tank is wider at the top than the bottom, so the level doesn't drop at a consistent rate! :thumbup:
For my London driving over speed bumps and traffic queueing, I reckon I get about 22-28mph. (edit Sorry, mpg, about 16 mph). As a female, I quite like the 1.4 as it looks like a proper car, rather than a small hatch that someone will carve up. I like it for safety rather than mpg TBH.
After driving bigger cars, it's noticeable when moving to a smaller car that you need one that holds its place on the road. That shouldn't be necessary, but it does make a lot of difference in my opinion. Not a bad car either :) (given my yearly repair costs being an X reg).
Mo
They should space the markers on the dial accordingly :rofl: :P
Truth is, Pembo, that each car of any make will be different. Might be perfectly fine, just have to get to know them. (And yes, I've read those sites where every piece is hand carved to make a car travel faster for when they do the tests.)
Another truism is that you have the car you have. Unless there's Super glue on one's driveway of course. :doh:
Mo
I still think you should be getting more MPG , mine is 10mpg better than that , consistently , over the last 2 years. Which MPG readout are you looking at , there is one that only reads the last trip (MFI 1) , and the other one (MFI 2) records for the last 9999 miles ,100 hours engine use or 1000 litres of fuel. Id expect the average figure on the 1st readout to be between 36 and 38 MPG round town.
PS did you know you can reset both of the memories by holding the reset button (on the base of the wiper stalk) fore more than 1 second. Maybe you should wipe both memories now and start from scratch , then you would be measuring only the MPG since you had the car seen to?
i get about 32-33 round town, does that sound about right? If i really try and drive on a night a lot i can get about 37-38, and on motorways forty something??
Just filled up tonight 249 miles and it was 40.24 litres to fill up so I make that 28.1 mpg bit better.
I can't believe there was 4.8 litres left in (over a gallon) as I was on virtual empty I wouldn't have fancied trying to go another 5-10 miles never 25-30ish.
Just shows the needle is a bad indicator as I had a quarter of a tank in when picked up from garage on Sat and it did 50 miles same as normal but I seemed to have picked up a couple more mpg somewhere.
Heresmo your figures are nearly as bad as mine although our driving sounds the same my town to work an 8 mile trip I prob average about 16-20mph.
As an afterthought, I'm not sure how old the cars are that we are all talking about (mine's a Y reg not an X as I said, doh). However, I am always told at service time that it "needs a good run". Doing that can cause its own problems unless a bit steady, so not to go berserk in one blast BTW.
The mechanic usually quips that if you have square wheels from long hours standing time, it's a good clue LOL, as seemingly engine bits can go square, as well as fugged (clogged) up.
I'm wondering Dmac1969 if you get out for a "good run" some weekends, hence your better mileage?
Mo
My Dad always used to take my Gran's car out for an 'Italian Tune-Up' when we went down to visit, as she only ever drove it to the shops. Quick blast to Portsmouth and back every couple of months supposedly helped keep everything ticking-over between visits...
Must say that after doing a long journey with mine a few months ago it felt much better and the cream off the filler sorted itself out :thumbup:
Mo
Not really Mo! The car has only left town 4 times in 2 years! Most days it does 2 miles , then sits at work for 8 hrs , then does another 2 miles and goes back in the garage till next morning!!:) Ive done about 7000 miles since June 2005 , but still see 36 to 38 MPG on the readout town driving , unless town is really clogged up with traffic , then it could head down towards the low 30s. On a run to Edinburgh (dual carriageway , 80 ish mph most of the way) I got about 43 MPG , and a run to Lauder in the Borders (Twisty single lane A roads , low average speeds between 40 and 60) I managed to see almost 50 MPG on the screen! I recently managed to make
I purchased the 1.4mpi 8v and also had the same problem with crap fuel and sluggish performance. I think for the size of the car the engine just doesnt have enough power same as the golfs a 1.4 engine in a golf is a waste of time, i sold the 1.4 and purchased a used 1.9tdi alough i now have a long list of common probs with the older fabias fuel economy and performance and brilliant.
I am just coming to the end of my first tank since the thermostat was replaced and I am looking at getting 270miles out of the tank which is only 20 more than before.
Also this time I had a run out of about 35miles motorway driving but I was doing 90mph all the way.
With having the run out I thought my figures would go up anyway so my town mpg hasn't really improved or does driving at 90mph cancel its self out.
I'd've thought you'd probably only get 40mpg tops out of the MPi at that kind of speed - I was driving SWMBO's MPi at the weekend on the motorway, and was getting 50-55mpg at a relatively sedate 70. What with wind resistance being proportional to the square of speed, and the Fabia having the aerodynamics of a housebrick, I can imagine mpg in the 30s being entirely possible at high speed...
Mind you, having said that, the thrashing should have helped clear out any gunk in the lines, so maybe things will improve...?
Thats why I was doing the speed I was.
I had noticed that performance was dropping off again going up hills etc so decided to give it a quick blast down the Mway.
We shall see when I work the figures out in the next couple of days hopefully I might hit the magic 30mpg mark.
Joy!!!
If my calculations are correct I think I have hit the magic 30mpg mark.
On my last tank I have got 30.67mpg this included a 30mile run at 90mph on the Mway.
I managed 262 miles out of the tank and was halfway in the red would have got to 270 without any problems last time I was nearly on empty at 249.
Does anyone have the litres/gallon figure I should use I can't seem to find it even though I know it has been posted before.
Still don't seem to undertand how there can be 6 litres left though if I was well into the red does the reserve not kick in until you hit rock bottom or something?
:woohoo: Best thing to do to avoid having to factor in the size of the reserve tank, is to do a proper 'brim-to-brim'. It sounds like you've been doing something similar, but the trick is to fill the car right to the top (first click only, though!), reset your trip meter to zero, drive around as you normally would, and then when the time comes to fill up again, fill it to the brim again (one click as before), and take a note of the amount of fuel you added to refill the tank (it's on the receipt of course, if you forget!). You don't need to be empty, but the more of the tank you use, the more accurate the calculation will be! Check your trip meter again, and divide the distance you've driven by the amount of fuel you used. This will give you your fuel consmuption in miles per litre, which you can then multiply by 4.546 to get miles per gallon.
Hope this helps! :thumbup: (Or sorry for teaching you to suck eggs! ;) )
That is exactly what I have been doing
38.84 Ltrs/4.546 = 8.54 gallons
262/8.54 gallons = 30.67mpg
My reserve tank comment was just a side issue that I can't believe it could run anther 30 miles as the needle is rock bottom.
  • 1 year later...
Thought Id pull up this thread rather then make a new one....
Ive got a 1.4 MPi petrol and was mulling over whether to clear it out with some Redex as like Fabia1.4 it seems to struggle up hills and the MPG isnt so good. Just a few questions though:
1) Anyone ever done this and would recommend it?
2) If so, which one should I get...as a quick browse of Halfords showed 3 different types for petrol engines. Theres One Shot, Petrol Treatment, Injector Cleaner and Fuel System cleaner. Im confused as to which one I should get if I do try it :confused:
