Ecu pinout diagram
Hi does any one got the ECU pinout Diagram for Octavia Vrs '03
Need to connect Apexi S-AFC II, Apexi AVC-R and Apexi Turbo Timer
Pinout for:
IG Power
Ground
RMP Signal - Injector Signal
Throttle Signal
Knocking Signal
Airflow/Pressure Signal
Speed Signal
O2 Sensor Signal
Thanks!
The only info I have at the moment is -
VAG 1.8T bosch ME 7.1 & ME 7.5
Ground: P1,2
12V: P3
Ignition: P62
K-line: P43
thanks, will start working on that, it will all come in the end :)
ps, i have the J220 ecu
Thanks :cool:
the engine code is AUQ can use from VW must be the same engine AUQ
Do you still need info on these? or have you got them already?
I can't recall anyone here fitting those APEXi components to the 1.8T engine. I know that the AVC-R works brilliantly on my son's Nissan 200SX S14a having helped him fit it but are you sure it will work for you?
  • 8 months later...
I too need the pinout diagram to fit the Greddy ems system. Please help.
