Engine bay "under tray"
It appears that there should be a plastic undertray beneath the engine bay to protect all the "oily bits" from muck and spray off the road. It looks as though it should be in two halves, one forward of the sump drain plug and one to the rear of the sump drain plug. Is this correct or is only the front half fitted as standard?
My 53 plate Octavia vRS only has the front part fitted. Is it likely that the rear half was never fitted or is it common practice for lazy dealers to just forget about refitting it after a service?
If my suspicions are correct, does anyone think I could pick one up from a dealer for free?
Probably not for free, but they will sell you one.
Scrap yard is your cheapest bet.
I wouldn't bank on getting one for free and I doubt it would be down to a 'lazy dealer' not replacing it either.
I looked into the price for these and I think theyre around the 30 quid mark. Mine has gone amiss too.
mine was ripped off when i bought it as there are still pieces attached at the fixings so when i have got a spare
do not buy the plastic one they just come off a complete waste of time. Hence why so many are missing.
However the metal one is of interest anyone got a web link to a pic / price of one?
vRS Si has or had one for sale, have a look in the classified to see if it is still available.
The petrol engines only have a small under tray at the front
Diesels have the full length tray, cuts down on clatter.
The metal one is available from dealers and has been covered several times on here. You might find a diagram if you use the search.
As Lee says there was one for sale here.
Most likely been ripped off like two of mine were going over bumps on bad roads.
mod please dump this as i got the wrong part
