Do LSDs need special gearbox oil?
My mind says no, as the diff is just bolted on the back, and the actual oil is used for the gears. :confused:
Either way - Anyone recommend a decent performance gearbox oil, if there is such a thing. Shall soon be filling up my spare 6 speed complete with Peloquin, so would be good to be fore-armed, to make the swap over as painless as possible. :)
The gearbox oil lubricates all moving parts in the gearbox including the diff, but no you don't need a special oil, but a good one always helps.
I might have a word with Opie - He's on here isn't he?
It was your gearbox oil thread which triggered this thread. :D
I'm using a different one, specificed against Honda's. And it's much better, but no. They don't need a special one.
Will probably just slap some 75w 90 in it then (or whatever the normal stuff is)
lol! sorry Dev!
some diffs have separate, self contained oil; by the sounds of the other posts the Skoda setup utilises the gearbox oil...
Opie is on here... haven't spoken to him yet tho...
Motul do separate oils - for both gearbox and LSD fluid:
PDM Racing - Motul Lubricants
Don't wanna give you any further advice! might owe you a new LSD! speak to Opie and see what they say (I might call James @ JBS in the morn and ask what he thinks)
PS: attachment is of standard oil from Stealers (am on with changing it this weekend!)
16145.attach
Taken from the Quaife website:
.......a maintenance-free design which retains the standard oil lubrication.
Think this might be specific to the application as the new Megane R26 uses a different oil for gearbox and LSD.................l believe the Focus RS also has different oils specified.
The quote I posted is specifically from the 02M application page.
What type of LSD is it?
A Torsen type (inc Quaffe ATB) doesn't, a viscous coupling doesn't, a "Detroit Locker" doesn't, but a Salisbury type may, and I'd refer queries about them to the manufacturer.
Peloquin is pretty much an exact copy of a Quaife ATB.
