Synchronize keys
Hi,
I changed the battery in one of my 2 Octavia keys but now the remote locking doesn't work anymore. Consulting the handbook I found this:
The keys must be synchronized
Press any button on the key and within a minute open the door with the key.
Well, I did that but it still doesn't work. The little red light on the key flashes when I press the buttons.
Any suggestions?
Thanks,
Peter
You could try -
Using a spare key switch the ignition on.
Insert the key to be programmed into the driver's door lock.
Manually lock the driver's door using the key.
Press the Lock or Unlock button on the fob once.
Wait for a least one second.
Press the Lock or Unlock button on the fob twice.
Just tried that but no luck. Anything else?
Just a thought
Got the right batteries in there
Yep, same ones as before.
Just to make sure I didn't misunderstand the instructions:
I use my working key to switch on the ignition
With the ignition still on I insert the to be programmed key into the driver's lock
I turn the to be programmed key in the door lock to lock the door manually
I press the unlock button on the to be programmed key once while it is still in the door lock
I wait for at least 1 second
I press the unlock button on the to be programmes key twice
Is that correct? Needless to say that the horn doesn't sound...
If it won't synchronise, it is likely that the remote has had it.
  • 2 months later...
Thanks VRStu, had the same problem with my spare key, just been outside and fixed it!
  • 3 months later...
im trying to do the same thing ,but i cant seem to program the second remote, i do as said and all works great. i get the originally working key out of the ignition and now this one no longer works but the new one in the door now works. very annoying am i missing a simple second step?
