Fabia Vrs reversing light switch
Iv got a 04 reg Fabia Vrs and the reversing lights dont work,also the rear wiper doesnt wipe when the front ones are on and you select reverse,does anybody know where the reversing light switch is? or what the problem may be? any help or ideas would be most welcome as everything else on the car works!!!
  • 2 years later...
Does anyone know the answer to this on? Also, if I went to a dealer would anyone hazzard a guess at what it might cost to get fixed?
Check if your reversing lights work too, most likley the switch on the rear of the gearbox requires replacing, fairly simple and inexpensive to change, quite a common problem on here, if you search on posts in the fabia 1 section with "reversing" in the title it throws up a good few hits,
heres a starter for ten: http://briskoda.net/fabia-i/reversing-light-switch-again/113313/
