Lowering Springs for felicia pick up?!
Does anybody Knoe where I can obtain a set of lowering springs for my 98 felicia fun pick up? Pulling my hair out cos I can't find a source anywhere! Thanks.
What i have found out, you can get springs for it here in Denmark, and they are made in Denmark to, it lovers the car 35mm.
Or you can use Golf4(Read Golf5 GTI on the net somewhere) springs.
Or get AIR suspension.
And the getto mods:
Heat the spring = easy, cheap, but not road legal and very unsafe.
Cut a slice of the spring = Easy, cheap, and not legal and safe.
Find a spring with the right lenght and thichnes, get some adapters made, to let the spring fit the rear suspension.
In the front, just use regular Felicia lowering sets.
Best Regards
Morten
  • 2 months later...
what springs fit on the back? are thes the golf springs
Rear Mk4 Golf springs will fit.
would that be standard mk4 rears, of lowering springs for the rear of a mk4?
Either will fit wont they, as long as you don't got for more of a 35mm drop on the rear you should have any majour shock issues.
I reckon someone would make a mint if they made a small batch of springs for the Skoda/Caddy pickup.
what about shocks if they need to be changed.
if you put standard mk4 springs on it will still have the same ride hight .
i heard it is the lowering springs from the mk4 golf, that is needed in lowering the pick-up.
its only for the rear.
i don't know if the come as just rears.
i've just sarted to look into it.
  • 1 year later...
Dudes does this go for the estate aswell.....p plater ?...nath:confused:
no, the estate suspension is the same as the hatch not the pick up
Thanks dude...so mk4 rears are a dffo then.....nath.
