central locking problems.
ok a little problem,
i have is that one door doesn't work with the central locking, im ok with that its only 1 door and hasnt worked since i had the car.:(
BUT.
tonight i stopped the engine and when i tryed to get out the car it locked me in!
the door button wouldnt open or close it was stuck halfway.:eek:
So i got out through the passenger side, and tryed my key in the drivers door it still wouldnt budge, so i closed the doors and set the alarm
(which activates the central locking)
this locked the door and allowed me to use the key to open it.:thumbup:
problem gets worse, the central locking isn't working at-all now. :thumbdwn:
:mad::(
nothing would make it work, seting the alarm or using the key. and the alarm was a bit odd,
1 beep arms it, 2 beeps usually disarm it, but didnt beep twice, 3 beeps dissarm the alarm after its been activated, it skipped between 1 and 3 each time from its usuall 1 to 2.
when i got home the alarm stoped beeping 3 times, and started beeping twice, however stil no central locking, so i locked the doors from the inside and tryed to push the passenger side lock down but it wouldnt budge
so i closed the door and used the key i then armed the alarm,
Just to check it i dissarmed it and the central locking is working fine again:eek::eek: :thumbup:
oh in case you were wondering the spare keyfob battery was dead, so no luck there.
ANYONE KNOW WHAT HAPPENED, HAVE YOU EXPERIENCED THIS B4?:confused:
anyone??????
only thing i know of is that the inside of the barrel can corrde sometimes and stick, and then the key wont turn properly
