Knocking noise when turning left
My Octy VRS 2003 seems to have developed a knock/Clunk coming from the front offside whenever I make a left hand turn. Seems more noticeable when accelerating and turning such as turning onto another road. Any ideas ? I get worried when things start making a noise as though they could fall off :slant:
Droplink at a guess. cheap fix and common on Octys
Could also be a broken suspension spring, if it is get both front done at the same time.
When i had my octy vrs it did it worat when turning on full lock going in or out of my drive way!
Thanks for the replies.
The suspension feels fine normally. I am guessing that if a spring were broke, I would get a knock over bumps? It sounds fine over bumps, potholes, speed humps, etc.
Re: Droplinks. What part is this then? Is it a fairly straight forward DIY job, or is it a mechanic/dealer job?
Could be the outer CV joint, its the wheel that under load while turning that makes the noise just like you have.
I had this problem on my old citreon, got worse, faster and louder as time passed, then the gaiter split and dumped the grease all over the brake disc nearly killing me in the process. Braked hard on the motorway and the car lurched onto the hard shoulder all of its own accord.
