immobilizer
Hello please can someone tell me how to find out if my car has a immobilizer fitted thank you
You would need to give us a little more detail about your car. I would think it was quite likely but I'm not 100% on the Felicia.
Standard on even the humblest models from Apr 1999
I have never seen a UK spec Felicia without one. It has been a requirement that all cars sold new since about 1995 should have a factory fitted system.
Solit the key and look to see if there is a transponder chip inside, this will look like a scrap of black plastic.
Hello its a S reg 1.3 lxi felicia
Hi can you take the transponder out of the key to use with a new key or is it attached to the metal part on the key thanks
it will swop over into a new key so you dont have to have it reprogramed
Hi thanks so just to make sure I understand it correct the little transponder is not attached to the metal part of the key.
thank you
if i remember right at looks like a little glass or plastic medicine capsule
Just remember to open up the key in a well lit area or you might lose the chip form inside the key...just as i did recently!
