passengerside glovebox rattle
hi all . just a quick post to follow up my previous posts on this.
i have fixed and found a cure for the persistant rattle noise that comes from behind the glovebox on my fabia vrs.:)
If you have padded out and secured all your wires behind the glovebox and you have padded out the windscreen washer pipe tubing underneath the scuttle panel trim and you still have a rattle noise this is the fix :thumbup:
the fix is this= open the bonnet . look at the two bonnet hinges. you will see on each one of them a small black plastic block.
1).remove the passengerside plastic block
2).put some plastic or foam tape behind the bonnet stay locating clip .
hey presto the noise has gone!!!!!!!:thumbup: :thumbup:
the rattle appears to be caused by this plastic block vibrating against the base of the inner wing when the bonnet is closed causing inturn the bonnet stay clip to rattle .
this noise is transmitted into the car from behind the glovebox.
it took me ages to fix this noise but now i can say it has gone and i have no noises at all from the dashboard!!!!!!!!!!!!!!!!!
the rattle that i have had for over a year has now gone :thumbup: :thumbup: :thumbup:
Deleted by MODVRS
Edited by MODVRS
Thanks for the hint kt. Have got a rattle precisely like the one you describe and it is so annoying. Will give it a go this afternoon and see what happens!
took me ages to find this rattle. skoda dealer said the dash needed to come out!!
any way pleased i could help
yes its a right liitle nasty rattle that one to find and yet seconds to fix
excellent
mine does this - will try this fix tonight.
Mark
Could somebody please make a photo of the place where the fix should be treated? Even the pictuire from mobile phone camera would do the job too. Thanks a lot
Yeah pics would be usefull, I feel like I've had a go at this but nothing came of it:(
send me a email and i will email you back a photo.
Deleted by MODVRS
Edited by MODVRS
two more pics . . .
no problem guys and girls in posting your photos, saves me a job ====== yep thats the pictures of the said cause of the rattle for the glovebox that i was going to take I can confirm .
a question for MODVRS- has this fixed sorted your rattle then ??
can all members who have tried this fix let us know as i would be interesetd how many cars where like this and it wasnt just mime .
best regards to you all .
kt600
Thanks for the pics, I put some cardboard behind it...but didn't do anything to the block...and the noise is still there.
Ill try the block when I have some time!
Deleted by MODVRS
Edited by MODVRS
Ive got to do this. I have this really nasty rattle that this may fix...
Just removing the black plastic block stopped my rattle..... Just the gear stick rattle left to fix.
Alex
The gear stick rattle is the most annoying. Its like a drill!
I put some high density foam around the black block on the bonnet and the rattle has stopped. Thanks so much for pointing this out, without your help I doubt i would have ever found the cause of that rattle. Saved me a lot of headaches :thumbup:
kt600
For weeks I've been trying, without success, to locate the source of the low-revs rattle which I'd have bet my life was coming from somewhere around the glovebox. Having read your post I decided, with some scepticism mind you, to try the bonnet catch remedy. Eureka! it worked. Rattle no more. Thanks a million . Without your input I'd never have looked at the bonnet strut clip as a potential source.
I think I have the same rattle as this thread fixes.
The rattle occurs at exactly 1500rpm when slowing down in gear. It sounds like it's coming from the glove box but it's not.
Oh and it's soo frustatring when it does it....
is this the same thing?
It's really not that much trouble to have a go at fixing it. I just folded up a post-it note and rammed it behind the locating clip.
30 second job, if there's a chance it may cure your rattle it's well worth it...
  • 2 months later...
have just applied this fix and will see if it fixes it....will update later!
Never even knew this thread existed but i fitted the foam ages ago lol, stops it rattling, nicked some from work ;)
No sooner had I solved the "glovebox rattle", than another one developed. This one only occurred at low-revs. After much searching I finally ID'd the source - passenger seat belt anchor vibrating against the centre console. A bit of self adhesive foam padding between the two solved the problem. Happy days.
Didnt fix
Worked a charm for me - still a tiny tiny bit of noise - despite some foam tape both underneath on the metal strip and behind the clip - but a major major improvement!
barely noticeable now.
Many thanks for posting! - hope it's also posted on the common fabia problems sticky...
Bas
