Tailgate washer not spraying
My new Fabia 1 (1.2 HTP 47Kw) fails to spray when i try to operate the tailgate washer system. The motor does sound like it's operating but no water comes out. The reservoir is full. Any suggestions as to what I could try please? Thank you as always.
A common problem is the hoses popping off. Usually, in the boot lid.
as above but also from under the bonnet, near the back of the engine bay. tell tell signs are a big wet patch under the front of the car :)
Thank you guys. I tried again and this time it worked. Apparently it was cos the system had never been operated previously (hopefully).
Thanks again
good news then :D
saves you getting mucky under the car!!!
Same as the Ibiza then :P
