Boost gauge
How hard is it to fit a boost gauge to the fabia vrs?
I am thinking of getting de-cat and want to keep an eye on what the turbo is doing.
pics and links to suitable kit if possible?
Joel
boost gauge isn't too hard I guess it needs tapping into the intake pipe. I've see it tapped in the the pipe running from the turbo to the intercooler. Jason devontopia (sp?) has one fitted so does flatfourburble. I only know this as I've searched for the info myself. Use the search button and it should bring up the posts.
hth
And remember you will need a 2 bar gauge.
either you take off the intake manifold and drill/tap in a fitting, or you put in an allard racepipe and it has a nipple for the gauge all ready to go....
HTH
Bas
