Felicia Squeal from engine on start
Hello,
I have a 1995 Felicia. I have figured out the sound that i hear when i start my car from cold is a squealing sound from somewhere under the hood. The sound goes away after about 30 seconds of driving. Any ideas? Thanks in advance.
Ritchie.
sounds like loose alt belt
Thank you for your response.
Does it need tightening or replacing and is this a problem i need to address right away?
Thanks again,
Ritchie.
probably just loose but check it for any sign of cracks or splits replace if you find any, sort it sooner than later cause as winter comes you are going to be using heater, lights etc etc so the alternator is going to be working hard
Cheers Andy
