mapping / computers / routes
I wonder whether anyone has solved this problem in the past?
I have a list of about 200 post codes, and for each of these I need to know the distance and traveling time from a central site (again I have the post code).
1) Does anyone know of a web service like www.viamichelin.com but which exposes an XML interface?
2) Is this something that I could do with AutoRoute?
3) Or a non-microsoft alternative to AutoRoute?
4) Has anyone used MapPoint? This sounds a bit like what I
Si,
Would be interested if there is a way of doing more than one at a time as I'm just about to start a similar piece of work. In the past I've had to do them one at a time in Multimap or similar - which does get a bit wearisome.
Jane
Autoroute should do this as I have autoroute 2002 and you can plan a route using Postcodes.
Cheers.
Do you know if there is a COM interface to this? IE, can I script it, or will it be one at a time?
See you at about 2030, BTW
I use Navigator and this also does this.
Used it on the cannonball run but didnt have euro postcodes :( Luckily we got a taxi to take us to the stage finish hotel in Barcelona !!
I think you need to talk to our esteemed webmaster. He was doing a thing where you input a postcode and it told you the distance to a fixed point eg Jabba and then was looking at one that gave you distance to dealers within an specified area of your "home" postcode
I use Mappoint all the time. It is expensive, but it's one of the perks of having an MSDN subscription ;) I believe it'll do what you want, but I've not tried it - I usually use it to map out a journey, but it lets you put in your average speeds on different types of roads and is reasonably accurate.... :) I'll have a play with it and let you know.......
Also lets you plug in your GPS via COM port :thumbup:
Chris
I noticed that it comes free with an MSDN sub. I wonder if I can persuade work that that's what I need :rolleyes: :rubchin:
Ta muchly :D
You know that Mappoint is Autoroute (like a ++ version though with loads of added features)?
You could write a little harness prog which sits there skimming through your list routing and saving the results.
I wonder what service he was using *where's the Sherlock Holmes smiley when you need it?* Edit: :holmes:
Yes, but how to automate? :confused: And I'm not resorting to SendKeys! I've grown out of that :rofl:
You need mappoint and the mappoint dev kit. It's great, one of the best product Microsoft bought ;)
If you have an MSDN subscription just download it from https://msdn.one.microsoft.com if not then It aint all that cheap unfortunatly.
Yes, but how to automate? :confused: And I'm not[/b'] resorting to SendKeys! I've grown out of that :rofl:
You will need to write a prog in C++ or Delphi - or if you can't program then you could use VB :rofl:
The prog will go through a list (read from a file/spreadsheet whatever) and pass pairs of postcode to Mappoint + save the resultant miles + times to a file. All done automatically - no probs.
Yeah, I know how I would do it in MapPoint, (it exposes COM interfaces) but not whether AutoRoute would do it.
Anyway, I hacked a WebBrowser control together, built a querystring + post data and then did a:
JDistance = WB1.document.getElementById("itidist").innerHTML
JTime = WB1.document.getElementById("ititime").innerHTML
to read the answer. Not terribly elegant, but quick and free.
Oh, and I was brought up on C, but find that C++ is too much hassle for a simple hack, like this, and I'm too lazy to do all my array bounds checking myself (so I use VB). :D
So thank you, problem solved. And I didn't realise that MapPoint was sold seperately from its SDK. Is this the case?
Yeah - i think the sdk is free download from M$ but MapPoint @ 230 a pop is not :)
