second fuse box inside car..
Where is it?
To the right hand side of the dash, it's easiest to see it with the drivers door open.
thats the first fuse box.
I thought there were only two? That one in the dash and the one on top of the battery?
that's wot i thought. :confused:
let us know if u find another... ;)
My Auto Data CD says there are more! very odd!
My source says there is just one "fuse box" - you're not referring to the control box under the steering wheel are you? There's quite a few little ECUs, but all fuses are located in the side of the dash, or the main one atop the battery.
Not aware of any other fuses anywhere else. :confused:
The relay plate has some thermal cut out electric window fuses, take the cover off around the pedals and look up.
That's what I thought - hence my first post.
odd! this list alarm fuses etc too lol
anyhow, it seems that the issue is sorted :)
Thanks for your time and help / info :)
For what it's worth, there are two fuses under a black plastic cover to the left of the wiper motor under the scuttle. No idea what they do...
