VRS headlight assembly
Hello there, was wondering if anyone knew whether or not the headlight glass front could be removed on the vrs?
If it can, does it involve resealing it/replacing the glass?
Many thanks.
Think that is a no, the lens is moulded to the light body
Many thanks.
It can be removed, using heat from a hair dryer or even hotter from a paint stripper gun, then it would have to be resealed with silicon of some sort
Why?
If it is condensation then the same heat applied with a lamp removed and applied to the opening would clear it, so you would only need to split if you were painting the base black or removing some stain?
National aka Jimbo
Cheers for the help.
I am looking to install a pair of white LED-strip sidelight 'bars' inside my headlight assembly similar to the Audi R8 LEDs.
I did notice that the headlights have a couple of retaining clips on the top of them and was wondering if prising these off would do the trick?
think there's a post by Jason with pics on how he opened his set up....
HTH
Bas
Does the bumper have to be removed to get the headlight out?
