Fuel beep but lots of fuel
Ok, recently (twice in the last 3 days) just after pulling away in the Fabia, I have had the beep that would indicate the fuel light coming on but plenty of fuel. Is this something to do with the cold weather or does it mean something else? No warning light comes up on the dash.
Many thanks,
Duggie:thumbup:
Ususally when you get down to 4oC you get a warning bong, possibly that?
It might be the outside temp warning beep mine beeps all the time due to the cold weather
Ok, That'll be it... was 0.5oC where I was this morning. Thanks guys, nothing to worry about then!
-Duggie.
just wait for the day that:
it's less than 2 deg outside
you're low on fuel
you're low on washer fluid
you're due your next service
and you attempt to drive away with the handbrake on.
bing bing bing bing bing !
(and then, just for good measure, you leave the lights on when you get back out the car):shakehead
is there any way to delete double posts, not just edit them ?
Does the website beep if you do make a double post?
No.
No.
beep beep , lol
and another bing for a blown bulb is it not?
Davy
yup lol
is there any way to stop the beep from the cold weather warning? I know it's cold, I CAN FEEL IT!
At least they've got rid of the 5 beeps before you put your seatbelt on - now that was annoying! :rofl:
Chris
it's less than 2 deg outside - yep
you're low on fuel - yep
you're low on washer fluid - yep
you're due your next service - no service indicator
and you attempt to drive away with the handbrake on. - yep
Had 4 of the above at the same time!
Scared the **** out of my missus when she drove it away!!!!:D:rofl:
dougie, give me a shout if you want me to vagcom it to double check for ya.
