VRS...does it need a turbo timer?
Hi how you all doing?
just wondering if the fabia vrs would benefit from a turbo timer or is there one built in?
just i used to have a vitesse and there used to be problems with the turbo if you didnt let cool down after runs or giving it some?
I think it's the same with most turbo cars that if you have been driving hard/giving it some,don't pull over and turn the motor off.
It's not going to hurt to sit for a minute or so after a blast ;)
Diesel turbos don't get as hot as petrol turbos and for the most part, there is no need :thumbup:
Chris
But it would look good though.
thought diesel turbos dont run at such high pressures as the petrol ones do, therefore dont get as hot as them too?
i do sit in the car for a minute if ive been driving fairly hard, but its out of habit :) got it from my dad when he used to drive rs turbos etc!
A new turbo is a lot of money to fit if yours goes.......why risk it over being unsure how hot it gets? I always let mine idle after a hard or motorway run. Better safe than sorry IMO.
No no no no no no no no!!! ;)
Sorry?? :confused:
(Also, you've spelled Superb incorrectly in your Sig) ;)
cheers folks, just need to be earlier for work:P
read the owners handbook, says to let the engine idle for a couple of minutes after a hard run!!!
RTFM is an appropriate response to 90% of the questions asked on this forum.
Pressures are actually pretty high but I just let it idle down for a little bit if caning it, and were I to make progress on a motorway and pull into the services to refuel etc, I just slow down nicely to effectively cool it down a bit anyway. No need for turbo timers :)
VW didn't give the 130PD engine one... so it doesn't need one. Simple...
Diesel run higher pressure, but petrols have a higher EGT, thus hotter turbo.
harsh but true ;)
