Cost of new hoses/DV
Hi
Had the Engine Management Light come on last night:mad: Thankfully a friend at work has a vag-com cable for his TT. It has come up with the fault code 17705 which i believe most people have had and from reading previous posts i may as well change the dump valve and relevant hoses. (someone correct me if wrong)
So really all i want to know is the cost to have these replaced. I would do it myself but not really mechanicly minded.
Russ
Could just need the throttle body cleaned. A friends Golf gti sprung a 17705 code and was cured by having a clean
Noticed that it does have that as a possible fault throttle body ceaned and check alignment.
Is it a big job??
Nah it's smiple
You a need a new gasket (about £1.50)
Undo the four bolts that hold it on, get a bit of carb cleaner (£2.00ish) spray, clean refit. Get your mate round with vag com to re align
Loads of threads on here about try an advanced search
Excuse the rough picture 18338.attach
Here is thethrottle body with the big circle and you can see the top2 bolts in the smaller circles
Photo courtsey of stevie wonder (no not the blind one, he cant drive for obvious reasons. And if he could I doubt he wouls drive a 5hitty skoda)
Cheers buddy, Dont mean to sound like a complete tw*t.............but what do i actually clean inside it?
(You see the mechanical mindlessness is seaping through now!)
I got my gasket today so will be doing this Sunday morning.
£1.82 for the gasket
Carb cleaner and a toothbrush will do nicely
ah yes I get trade discount so £1.50 for me :thumbup:
Can you pick these up at halfrauds and so you need to go to the stealers?
