Hello world! any help would be great
hello all, sorry am new at this!!!! can anyone help? i have a skoda octavia 1.9td 52 reg with a little problem. when i use the indicators they work correctly but as they click themselves off the sound carrys on for a few seconds sometimes getting faster. after about 10 seconds all is well again until the next time you use the indicator
any ideas would be great
thank you
Often the hazard switch which contains the relay is at fault.
Try the search button.
Welcome
Welcome :)
thank you
Welcome to Briskoda. Your problem is a common fault and its your hazard switch which needs replacing. Cheap to buy over the counter in your main dealers and will take about 10 mins to change. Be careful not to lose any of the 4 clips on the trim around the vents and hazard switch when removing.
Best of luck
