Fabia vRS Questions
Having just ordered my new Fabia vRS :D I have a few question that I should really have asked the salesman, but I'm sure you helpful lot can answer them for me.
1) Does the car come with locking wheel nuts ??
2) Is the auto locking facility available, ie Doors automatically lock when the car reaches 10 mph??
3) Is the foldy key standard on the vRS ??, cause on the Leon its only the Cupra R that gets the foldy key.
4) Does the alarm have volumetic sensors ??
:confused:
1) Yes
2) Yes
3) Dunno
4) What alarm?
3) Yes :D
4) As Jon says - does the vRS come with an alarm or is that just the Elegance trim?
Chris
1)Yes
2)Its available but requires programming
3)Yes two as std
4)I dont think so, but will check
The info I got from Skoda UK says that an alarm is standard, thanks for your quick replies.
yes to the first 3
if you mean by volumetric sensor, the interior movement sensors, then thats a yes also.
yes I did, thanks Dan
Alarm: not sure about volumetric sensors.. i presume so.
if a car door is opened in any way other than the plip on the key and not started within 20 seconds, the alarm will go off
The vRS definitely has an interior movement sensor. Its the grille near the interior lights. If you sit in the car and lock it then move your hands around above the dash, the alarm will sound. I'm told there is a screw to adjust sensitivity inside the interior light housing.
So, basically, YES to all questions...
In a word... YES :rofl:
It definately has the volumetric sensors. A few days after I got mine I left a bottle of water in the car overnight. My alarm kept going off but I couldnt understand why. Then I figured out that the street lights were reflecting in the water and setting the sensors off. :rolleyes:
So, is that a YES?! :D
1)Yes
3)Yes two as std
4)I dont think so' date=' but will check[/quote']
Hi,
2) How do u program it ??
Eye
Get your dealer to do it or find someone with VAG-COM :) Check out the Diagnostics forum in My Skoda for a list of people ;)
Chris
Hi Buzz,
The answers to your questions ?
1, YES
2, YES
3, YES
4, YES, {The sensor is mtd in the front Map light console !
