rear brake pads
hi i've got though two sets of rear pads to one set of fronts in 37000 ish miles dose this sound like there is something wrong or is this normal for the fabia vrs:confused:
37k for 2 sets of rear pads?
The VRS hardly uses it's rear brakes so I would say there might be an issue
thanks for that got any idears why it would
have the pads actually worn out , or are you taking the garages word for it that they are worn , when there is actually loads left on the pads ?
my rear pads were changed last November , they had done over 50k , and were only changed because they had been on the track once to often and had overheated :D
metal on metal both times :eek:
hi the calipers must be sticking, or you've left the handbrake on ;)
handbrake not left on and caliber not stiking thanks for the idears
do you carry a lot of weight in the rear of the vehicle ?
if any any can help with a possable cure for this problem or reason i would be :) for a long time and sorry for my spelling in my post :o
most of the time its just me but some time s loaded up with people
or camping kit etc
How long are your tyres lasting? If rears not lasting much longer than fronts then pressure (reducing) valve may be at fault.
tyres are fine the back one s are lasting very well
nope i,m not that good
haven't been doing too much of this??
Nick Whale - Video Clip 4
How come I can't see this video (or any other video from this site):irked:
sorry i ment 46000 ish miles :o
still a lot of rear pad wear for that mileage
