TIP, TT arch vent and splitter fitted
Wow! there big holes! Any improvement though?
  • Replies 122
  • Views 11.2k
Personally I think they are a little big... it does look well done though :)
P.S find many small creatures / rocks being chucked into there?
Mmmm holes look a bit big,chance of stones hitting intercooler,or muck blocking air flow.
Well I dont drive through fields, if I did...
Besides, the arches get cleaned every wash anyway.
Hard to say, probably a placebo thing, but every little helps as they say.
Ethos, my DV pipe rubbed on my engine cover so I ended up cutting it back a little.
Looks ok I think.
That looks neat.
Like that small hole look.
Any idea on what drill size that is??
Looks ok I think.
Thats one hell of a neat job.I doubt mine would look that good :rolleyes:
I'll check the hole size on mine today.
Thanks mate.
Can anyone put up some pics of the splitters please?
Was just wonderin, do tou jus go to B and Q and get hte self tap screws?
what size do you need?
and lastly,
does the cupra splitter fit straight on the vRS bumper?
cheers guys
billy
There's pictures on the first page.
lol yea but i cant really see the splitter up close and what the fitting is like.
just wondered if anyone had a pic of one from a lower angle.
cheers
and lastly,
cheers guys
billy
Yes.
If you look in the octy 1 section for lcr splitter I did a little write up for fitting mine.
Hi guys.
Speant most of the day putting these on. First off the TIP, this was the THS from ebay for £81.
Looked ok but when putting the bottom vacuum pipe on the nipple at the bottom the nipple actually pushed through so I ended up having to jubilee clip both sides (I might email the guy and possibly get a refund for a black one as I'm worried it's not going to stay on properly!).
The TIP took around 1 1/2 hours with a mates help.
My main concern is that it touches a metal coolant pipe halfway down... after a drive home it seems fairly hot. I'm guessing this must happen to all aftermarket silicone TIPS tho?
The TT vent was a bit of a pain, fiddly is nothing else.. but looks fairly good now.
The splitter went on nice and easy, looks sweet too I Think ;)
That is all :thumbup:
Hi, I need some help with my splitter.
I have shaved off the middle clips down to the plastic and taken the lips off the surrounding clips, have tried to put it on but it doesnt seem to fit as the two ends swing out and dont look right when i bend them in.
have you got any tips on fitting it coz ive been at it most of the day wi no joy.
cheers
billy
Hi mate,
Yea, get two of you. It helps no end!
We lined up the center of the splitter / bumper and drilled the two center pieces in first. Then one of us "moulded" the plastic to an even line and the other drilled / screwed it.
You might find you need to make tiny cuts in the plastic to allow it to flex easier, it needs a bit of bending it won't just sit on.
Hope this hopes!
As ethos states with two people it is much easier.
The two end pieces do need a little persuasion to go where they are needed to, but should not need cutting. If you are having difficulty, Fix the front part first and then tape the end pieces in place with masking tape then drill the holes through. Then remove tape and screw together.
lol
cheers fellas, ill try it tomoz, ill put a pic on of the finnished item.
hope it works coz it looks ace on everyone elses car.
Go for it.....
I put one on my car yesterday, was a bit of a faff but looks pretty good.... I think. I'll see how it goes, might take it back off. I'll get some pics later seeing as no one has put pics up of a silve car with one on yet!
tis on
cheers for all the tips fellas ill put pics up later on today. looks ace
here we go
Looks Good .......
Dan here is a pic of my silver octy. I posted some more in ealier thread.
18895.attach
Actually got round this weekend to fit the TT arch vent to my motor.
Took a little longer than expected as I wanted to use the black flexy adhesive to hold it in place than use screws or rivets. This was a challenge as I had to clamp all the areas to get a good bond and the areas are not exactly straight. Had to keep the clamps onto the liner all night to make sure it adhered ok.
Results are I am very pleased.
What do you folks think.
19038.attach
