Rear wiper/washer???
has the octavia vrs got a rear washer jet/pipe as when i push the lever back it makes the noise but nothing happens and if it has mine is not working lol.
Keep it held in for a while as sometimes it takes a few seconds to pull through if it hasnt been used for a bit. Either that or a pipe has busted.
Check to see that the pipe is still connected, as its common to come off, and the water goes into the boot, or the rear hatch itself.
Agreed with both. Oh and when if does deliver it's a river, not a spray, if mine's anything to go by!
mine hasnt worked since i got the car, had the same probs on my mk4 golf aswell, pump is defo working, either a blocked pipe or jet, or a bust pipe as said.
The pipe sometimes comes apart on the drivers side of the boot behind the CD changer. This can result in some electrical problems as an electrical connection there becomes wet.
cheers for that, when i got the car there was a stain in the boot which looked like water but the bloke i got it from said it was where he had someone in to clean it and they must have spilt something......umm!!!!!! lol
As Fordfan says, except that the stacker is on the LHS of the boot!
same problem with mine iver just ignored i as dont reallt use it and not had time to fix it yet.
Hmmmmm that might explain it.
My one didn't work and I thought it was just struggling to draw the water through so I held it on for 30 seconds at a time and I did that about half a dozen times before giving up. No wonder my back window had condensation on the inside of it for a week or so afterwards :(
well i looed at mine today, found some rather disturbing results :eek:
I pulled away the drivers side carpeting in the boot, where i was told the washer pipe runs, it was alittle damp around the area, probaly where ive tried my rear washer a few times, but i found a large blue hose dangling :confused: Im talking a bid pipe aswell, almost like a garden hose pipe, couldnt see what it was attacthed to, will have to take the rear seats out i think, but im slightly worried that some one may have bodged it up at some point, will investigate more at the weekend and post some pictures of the horrific blue pipe :thumbdwn:
