Squeaking Front Window
This is really starting to bug me now :(. First went in for 'the fix' a couple of months back (the fix being re-lubing the runners) but after a couple of weeks it came back again. Had it re-done during a service (at a different dealership) and sure enough the same thing happened again so this time a new regulator was ordered and fitted under warranty today and guess what .................................. it started squealing again when I got home!! This is really pi55ing me off now, anyone got any suggestions?
Lubricate the window seal with Silicone???
Nope, that works for a limited time only then it returns. Been back AGAIN and still cant seem to cure it!!
Argh, this drives me crazy as well.
I narrowed it down to the brush at the base of the glass, the thing keeping moisture from going inside the door.
I have yet to find something that will lube that and not smear the window.
Time for that Yellow one then :D
Can't say I put my windows down enough to notice if I have such a problem - it is winter you know :)
Steve are your window seals furry or plain rubber?
If they are not the rubber ones with the furry top get these fitted. FWIW if you are out of warrenty I might be able to keep hold of my set which are due for replacement so you can have a FOC try.
Also if you are doing silicon, try using the grease as per the cage mod rather than the spray as this lasts a lot longer.
HTH
EDIT: Ignore that I know you're under warrenty :(
I had a go at it today.
With the window completely lowered I kept the rubber/furry seal at the base of the window pulled back a bit and lifted the window with the key fob button.
When the window was completely up i noticed there was a lot of dirt on the bottom of the glass that's always below the seal, so I cleaned them with wet tissues on a plastic card.
I then noticed there were two white plastic pieces that held the glass from underneath, so I flooded those with my trusty old WD40.
There were two coresponding white pieces on the inside face of the glass (visible with window down) which I didn't lube because I don't want WD40 smeared on the inside + the smell of it.
The result is it's not that noisy anymore, but not completely gone for now. I suspect it will get better as the WD40 has time to penetrate the mumified crap in there.
Thanks for the offers of help and advice :thumbup: but I've been booked in AGAIN for next Friday and have been assured of a fix this time. The Master Tech is off on a course with SUK early next week and has promissed to bring the matter up with technical so watch this space.
Update: it worked so well the next morning that I didn't bother to lube them again.
Seems its cured for the moment.
