How bad is the low sump issue?
Cheers for that, i should manage to fit my it myself, i work for a bodyshop so we should have tools to fit it! Will have to phone TPS in the morning to see what the trade price is!
Cracked the sump on my first Octy 1 on a rutted road. Noticed small leak and though it was a loose drain plug after servicing. My garage sorted it out with a spot weld no problem. Sump guard on later models should protect.
I wouldn’t be too bothered about the Octys ground clearance. I work on farms installing milking parlours and have only caught the sump once, this was due to the track having been washed away. Also I see a lot of vets in Octys and 1 vet even in an evo Tommi Makinen edition.
skud - that is reassuring. Your job will be sending you down the same tracks that I'll be doing. I'll now try to relax about this and look for a good deal :)
Actually, thought occurs. If I see a w-shaped track, I try and drive on the side of the W, rather than right in the deepest part!
