Alloy wheels + Clay bar
After 6 months of use I decided to give the wheels a good seeing to :eek:
Took each wheel off and cleaned inside and out with a dilute mix of Wonder Wheels but couldn't shift the baked on bits so I had the bright idea of attacking them with the claybar (after reading about it on here) and some Megs wheel QD and all of the crud was shifted with very little effort :thumbup:
Followed this with a little AG ultra deep shine, Wonder Tyres spray dressing and then 2 coats of Poorboys alloy wheel wax.
Oh, and I also did the rest of the car while I was there; 2 bucket wash, claying where required, AG polish, 2 coats of Dodojuice Blue velvet and Aquapel on the rear windows.
Not bad seeing as I was on double bubble at the time :rofl:
EDIT: a little tip for those who haven't tried claying the wheels:
I wouldn't use the same smallish piece of clay on any more than 2 wheels max before binning it. I used the same piece on all 4 wheels and the scratches were much more obvious on the 3rd and 4th wheel (photographed). The contaminant obviously acted as an abrasive and scratched the lacquer despite the QD lube and turning the clay regularly. The polish sorted 90% of the scratches so not a major disaster.
Lesson learned :thumbup:
You'll note the cleverly positioned hose pipe to prevent the 'Kwik-Fit effect' :rolleyes:
AFTER claying but BEFORE polishing which took care of most scratches
The finished result
Good info. :thumbup:
Good job you did there mate :thumbup:
Going to do the same to mine very soon
Kwik-Fit effect :D
Thank you kind folks :thumbup:
Yes the Kwik-Fit effect, 3 times over recent years where an alloy wheel has been dropped spoke side down but only by said fast fit chain :mad:
Should have posted a 'before' pic of a grubby alloy face but forgot :thumbdwn:
Nice job! :thumbup:
Cracking results there...............clayed my customer's wheels at the weekend as well..........best thing for getting that tar off..............:thumbup:
Good tip and info :thumbup:
Always nice to receive some good feedback :thumbup:
SWMBO wants her bloody 18" Zeniths done like that now as well :rolleyes:
good tip that, cheaper thanmy aproach which was sell my old wheels and buy a refurbed set! lol
.....and when you've finished hers you got mine to do so get a bloody move on! ;):D
Yes sir!
I am warming my clay as we speak :rofl:
Great post, pics and info! Thanks :)
Cool :thumbup:
:thumbup::thumbup::thumbup: Nice one...... My Sonus clay bars arrived the other day and it says you can use them on wheels but was gonna ask on here to see if anyone had tried it.
You've saved me the trouble now. :)
Dave.
Good work!! Trouble is everytime someone comes up with a new tip i get the impulse to do it, so guess the alloys will be off this weekend!!
Just one thing.
Which end of the crowbar do you use ?
:sofahide:
show me a piccy of this clay stuff. Whats it called?? who sells it???
Here's a good place to start :)
meguiars.com: FAQ -
this what i need???
The bottom one will do for starters
I actually used this stuff: Detailed Obsession
Most of the detailing clays out there will do the trick, as with most things in life, lubrication is the key :rofl: I used some Meguiars quick wheel detailer as the lube as it was all I had at the time but it had more than enough lubricity for the job. Just remember not to let the clay get too mucky :eek: - VERY important! You only need a small piece for each wheel and make sure it's pliable before using, manipulate it for a few minutes and it will warm up nicely :P. Once this is done just follow any generic claying instructions :thumbup:
If you have reasonably grubby wheels I would use one piece per wheel.
Just one thing.
:sofahide:
Believe it or not, a quick slap on the tyre and the wheel came off by itself :D
Yes - I was shocked too :rofl:
Just received some of that myself :thumbup:
Gonna have a go at the weekend
Glyn from Elite Detailer had my wheels off today and used some clay to get some stubborn stuff off.
What a difference getting the wheels off! They are immaculate now and with two coats of Jetseal, ready to go! He also cleaned the calipers and laquered them :)
Good info for people that :thumbup:
I've used small bits of clay in the past to get into the corners of spokes to lift off ground in brake dust. As you say, works well :)
I tend to use bars that are no longer good enough for bodywork. But take your point about potential scratching.
Cheers,
Steve
