Auto locking new fabia
Does anyone know how to activate the door auto lock feature on the new fabia
i woudl imagine if its got it, you would need to use maybe vag com to turn it on?
maybe a trip back to your dealers?
Mine was on by default so perhaps checking with the dealer would be worthwhile?
I thought it was standard on all Skoda Fabias with remote central locking, both MKIs and MKIIs.
Both our MKI and MKII has it on already.
I assume by automatic locking you mean it relocks after you have unlocked it when you don't get in the car within a certain amount of time??!!
Mark
No I think he means what we call Anti HiJack. Doors auto lock above 15mph and unlock when the ignition key is removed.
The speed sensitive locking @15KPH/8MPH, to beep or not to beep on locking/unlocking, single or double pull once locked to exit, to unlock only drivers door or all doors on 1st press of unlock, auto unlock when removing key from ignition... Someone let me know if I left one out. Can all be toggled in the same module. Typically the dealer follows a standard method on PDI(Pre-Delivery-Inspection). If it's not to your liking then you should be able to get them to reset this with the "1552" free of charge. Especially if it's already in for service... If not anyone on here with a Vag-Com plus appropriate cable should be able to hook-u-up.
Oh yeah I think I got the wrong end of the stick!!:rofl:
Yes Skisbp is absolutley right, all changeable via Vag-Com or by the dealers!
