Rear Washer nozzles
Hi,
Is there any way to adjust the way they spray?
I have looked at it but can't see anything obvious.
The outer one is set to high and misses the window completely and lower one only sprays halfway up the window. It means I get a big smear where the water is missing.
Any ideas?
Regards
I just used a needle to adjust mine
Yes just use a needle. The nozzle disconnects off too for ease of doing.
Hi,
Will give that a try.
I had the same problem and used a pin. I flipped back the plastic cover to make access easier. Took a bit of fiddling to get it right so that it hit high enough up the window without missing. At one point I could give the car next to me a complete clean as I passed!
Hi,
I think I only have an upper one and use a pin to move it around.
Should there be 2 on all the cars?
Hi,
Used a needle and managed to adjust it. It was bit stiff to begin with but moved eventually.
Did take me a couple of times moving it to and fro to much each time though:)
Regards
