Rear brake cylinder
I was wondering if a rear brake cylinder from a Favourit would fit my diesel Felicia, there are a few cylinders listed on ebay at the moment and are a bit cheaper than the 'right' ones.
Only the 22mm Favorit Pickup cylinders will fit the 1.9D and 1.6
the Fav saloon and estate are 19mm and will only fit the 1.3 Felicia
  • 1 year later...
I´m going to change rear brake cylinders to Fel 1.3i ´95 and I´d like to buy new ones before removing old. I have understood that Polo Mk2 cylinders would fit
Catalogue of local spare part store gives two bores for Polo cylinders 3.85—94: 15,87 mm and 19,05 mm. Bigger ones are bolt-on in Fel, right?
I can reply by myself, it really is with 19,05 mm bore and all brake parts are same than they are in Vento.
