Springs
What springs would you opt for with Koni sport dampers? Im also changing my wheels to 215. And Im hoping to drop my ride a bit :D
  • Koni Sport Spring Kits
  • Eibach Pro-Kit Performance Springs
what are the Pros an Cons of sport dampers and lowering??
an what are bump stops or bushes? :confused:
Eibachs are probably the best. :) Not sure on bump stops as I've never tweaked them on any suspension I've had.
Pros = better cornering, better handling in general, more sporty look
Cons = cost + you might rub arches if you lower too far (applicable to coilovers only, not the eibach pro-kit stuff)
See you tomorrow morning! ;)
KW's
I'm impressed with my new H&R springs
