reseting Octy engin light
i really sorry if this has been raised before i have a a quick scan through all the post and not much came up. i have a fault on my Octy that is intermittent and the garage cant find anything wrong with it. can i clear the fault codes form the ecu so when it happens again it is the only thing registered on the ecu so the garage can fix it .
Yes you can and you should.
so how do i go about doing this allusive reset
Vag-com
can i not do it through disconnecting the battery for an hour or so
Sadly all a bit of a myth really.
Disconnecting the battery actually puts more faults in.
