Ecu Fault Code Readers From Ebay
on my felicia it plugs in the drivers side foot well if you follow the plastic from under the steering wheel to the bottom its on the right and side black plug :)
Havn't had experience of those kind... but i bought a USB one to use with my laptop that worked fine.
Looks ok to me though. Says it works with the felicia.
Yes, I bought one and yes they do work on my Octy vRS.
They will read all the fault codes and reset them, you also get a book with them that lists hundreds of fault codes by number and what caused them, and also a web site that gives additional fault codes.
Obviously it will never replace VagCom, but very handy to keep in the glove box to reset from limp mode etc on an Octy vRS
