top up oil help
hi everyone hope you are all ok long time since my last post just wanting to check something how do you read what you current oil level is please? i cant make out if i am low are not? also do i need some 5w 40 oil to top up? many thanks cheers again
Dipstick - has a section which 'sticks out'.
Oil should be to the top of this section.
There should be markings IIRC
Check oil when engine is cold / has not been running for at least 20 mins and also try to do it on a level surface.
You must use an oil which meets specification VW 505 01. The following oils are approved to that specification (there are more):
BP Special Visco V 5W-40 (fully synthetic)
Castrol GTD 505 01 5W-40
DEA Ultec Diesel SAE 5W-40
Delphi Prestige Diesel Plus 5W-40 (synthetic-based)
Esso 505 01 5W-40
Fuchs Titan Supersyn SL PD SAE 5W-40 (fully synthetic)
Granville Topaz Diesel 5W-40 (semi-synthetic)
Madit 505 01
Migrol Special S-Plus
Millers XFE-PD SAE 5W-40 (semi-synthetic)
Motul 6100 5W-40
OMV syn com diesel
Q8 Formula Excel 5w40 (fully synthetic)
Shell Helix Diesel Plus VA 5W-40 (semi-synthetic)
VAG-branded 505 01 505 00 High Lubricity Engine Oil 5W-40 - G 052 167 A2
- (Part No: ZGB 115 QLB 00 462 - RRP £32.90 inc VAT for 5 litres)
Valvoline DuraBlend Diesel SAE 5W-40 (semi-synthetic)
Carlube 5W40 PD Triple R VW 505 01 full synthetic
Use the Dipstick you Dipstick! ;)
Aim for the middle of the two lines.
To fill up take the oil filler cap off (ontop of metal rocker cover) poking through the plastic cover and pour the oil in there
:rofl::rofl::rofl:
Plastic ;)
Top of the cross hatched area is the larget, 1 litre from the bottom min mark.
cheers everyone ha ha my oil does not even come onto the bit that sticks out does that mean i am ultra low on oil? many thanks cheers
Yeah, top up now, haha!
might as well take it for an oil and filter change
edit:put a bit in first
cheers everyone the low oil level light has not come on but could i be damaging my engine now? also how much does it take to fill up from empty? how much top up would i need then 1ltr or 2ltr etc etc cheers everyone
from empty its 5/6 litres,
For a simple top up a litre would do you, if your not confident which sounds you arent take it to Skoda for a service :thumbup:
cheers mate for that bugger getting a service done ha ha its not due one for ages yet ha ha i shall get a 1ltr top up and check the levels again cheers many thanks
The engine is seriously short of oil. I would strongly advise against driving the car until you have topped up with sufficient oil so that the level is within the 'hatched' section of the dipstick.
