Gear ****!
Anyone changed their gearknob on their Felicia?
Is it a standard change - screw off / on (with rubber insert)
Plus any suggestions for what looks good with the rest of the interior?
Colour? or Look - metal / plastic
number 7 pool balls look good but are a tw4t to drill holes in
wow finally something i can answer:D my gear **** was my first modification:D and a cheap one at that they call it a ford mondeo gear **** from the scrappies:D feels alot better then the original. http://file023b.bebo.com/15/large/2007/04/05/15/14642256a4019858785b414253822l.jpg
http://file023b.bebo.com/15/large/2007/04/05/15/14642256a4019859797b626918766l.jpg
there you go simple:D just changed the gater an screwed the new one on:D
i havent changed the **** but i have cut the gear stick down by 35MM
I have changed mine in the past - dead easy to do, just unscrew and then pull off.
Good good - all sounds pretty straight forward then! Although i do agree drilling a 7 ball could be quite trickly! Although my father seems to think otherwise....maybe i should set him the challenge!:cool:
Drilling a hole in a 7 pool ball, sounds like a new sport :D
easy job, richbrook do some smart stuff, nothing to over the top.
i replaced mine with a real pool 8 ball. drilled hole into it using a 16mm drillbit and a lathe. the wrap elecy tape around the lever and smack it on, job done.
goe well with black favorit interior :)
I'd love to see a picture of that!! :)
:Dwill try get one for ya
