Broken Underseat Storage Box
My Friend Broke His Passenger Side Under Seat Storage, Its Got His Tom Tom And Cd's In.
The Handle Has Come Off The Box And He Cant Get Into It.
The Car Is On A Y Reg So Its Ready For Scraps, Hes Tried To Break The Box But The Plastic Just Seems To Bend Then Go Back To Its Original Form. How Can He Remove The Box Or Make The Tray Pop Out Like It Would If He Was To Open It With The Handle ...
All Ideas Welcome.
Tried removing the seat?
As above.
It's held in by a few screws on the underside of the seat.
In fact, you could get away with removing the front seat bolts & loosening the back ones to tilt the seat back.
Hhhm ... Any Other Ways ?
The Whole Seat Thing Seems Like A Bit Of A Farce ...
Other than drilling or cutting the latch/door out..............nope.
NOW WERE TALKING (Y) Lol
Sounds Easier Than Removing The Seat. What Is It That Make The Draw Pop Out When You Pull Down On The Handle ? Is There No Trigger Button To Pop It Open ?
From what I remember, it's just an ordinary latch.
If you don't care about damaging the box, then either drill the latch out or prise it out with a large screwdriver.
HAMMER
HAMMER
Are you an engineer by training? :D
can you tell,
it doesn't show mate
Hammers are good!! :D
Just found a photo of my old storage box & there 2 latches, 1 either side.
Just prise the bugger out!!!
HAMMER
Definitely not a technician though, he didn't specify the weight.
Bash the beJesus out of it!
is this still going on???
as i said - HAMMER TIME,
Latches ... Do Explain Please ... :]
Still No Where With This. Someone Above Said Removing The Seat ... PLANS ? My Friend Wants Needs His Tom Tom !!
How Would We Go About Removing It ?
You need a bigger hammer!!
Approximately:
- Undo the battery.
- Unplug the seating wiring.
- Undo the 4 bolts to the seat
- Tilt seat back
- Undo the box and throw/put a new one on
- Reverse of this to refit. IIRC you are recommended to use new seat bolts.
All at your own risk and it's just a guess of course.
Jesus Christ mate. It's been 3 weeks & you still haven't got it out yet!!!
Just HAMMER the bugger!!!
i said this from the start
smash it or a pry bar would be handy
Well i did say he needed a bigger hammer and then followed with the instructions for the non engineering route.
