Flickering lights and chirping sound
Has anyone come across this problem before? This is occuring on a Fabia 1.4, 51 plate
On tick over the headlights are flickering and a sound coming from under the bonnet, clearly audible in the car, the nearest description I can give of this is a chirping sound.
Listening under the bonnet it is difficult to identoify where the sound is coming from, but it sounds to be near the battery. All connections etc look to be OK, and have never had any trouble starting the car even when parked for over a week.
Thanks for any help anyone can provide.
Neil.
You got a nest in there mate. :rofl:
Seriously though... I've no clue. I hope you get it sorted though.
Nothing worse than not knowing.
Flickering lights are a sure-fire sign of power steering angle sensor failure. This causes the power steering pump to move back and forth constantly, but only a fraction. As it moves, it drains power from the other electric systems (it runs at something like 30A!), and this causes the lights to flicker. It's probably also the cause of the noise...
There is a DIY guide for replacing it on here if you do a search. :thumbup:
It might just be a slipping alternator belt.
My lights flicker on my car too have been for quite a while but i haven,t got Elec PAS.
No, you should have hydraulic PAS - but the pump for the hydraulic system is electric! :thumbup:
