Bluefin help
Hello,
today after I tried to install my bluefin soft to my 1.9TDI...my car stoped...I can't to start the engine...the immobilised is active...and I can't to reverse to the original soft, bluefin retour a error code every time I try to remap to original file.
....I have a lot of problem with a bluefin module.
Before a problem to download a modified soft, I can't to connect to the server, a lot of Email, finaly install manually into the bluefin module,
then this...
Now I have to call my dealer to bring my car at home....:(
I would suggest you give Superchips a call - I'm sure they'll help.
Yes I did it....and now is ok.
Superchips was send a wrong file for my car.
With a bluefin installed, I fill the difference, the car is't more more better.
That's good then.
Can you update the other 3 posts you made about your problems please.
