Good cheap perf mod? comments please
Is this a good idea for yet another Pikey mod?:
The OEM setup connects the crankcase to the air intake after the airfilter, in order to burn off oil vapours and vent crankcase pressure build-up.
I've read that by using a catch can (or venting directly to atmosphere by a long heater pipe ended by a small filter) you get:
no hot/ oxygen depleted air drawn into the air intake (and we go to great lengths to use cold air intakes, etc)
no oily buildup decreasing thermal transfer/ IC efficiency
(for petrols) no theoretical drop in octane rating. (Dunno about diesels...)
?? less crankcase pressure, less energy wasted in overcoming friction
?cooler running engine
downsides:
vent to atmosphere is irresponsible, illegal, dangerous to motorcyclists. Catch can is safer.
slower engine warm-up in winter/ during frequent short trips
If the pipe blocks can build up crankcase pressures/pop out the oil stick (?)
Any comments?
Bas
A catch tank isnt a new idea (got one for the Golf) but is a worthy mod in my book.
The God of all things VAG has spoken. :D
What I meant about new idea - it's not reported as a performance-enhancing mod a lot on Brisk.
Do you find a noticeable difference with it on Ross?
