Power steering Failure - Can I still drive it?
  • Please log in to reply
16 replies to this topic
#1 Grant
Grant
    Briskodian
  • Members
  • PipPipPip
  • 262 posts
  • Car:Fabia Comford TDI
Posted 16 August 2010 - 21:22
My power steering has stopped working. Doing a search on here would suggest that it is likely to be a connector that has worn through or the pump has died. I'm thinking it is the connector that has gone as it originally stopped working on Saturday, but has worked fine yesterday and today, but stopped working when I took the battery out to check the fluid level. I've also ran a Vag-com scan and its come back with error codes 00566 - Steering Assistance Operation: Implausible Signal and 01288 - Terminal 30; Steering Assist: Signal too High. These also suggested it is the connector.
I'm not going to be able to have a look at it until Saturday at the earliest, apart from its really heavy, is it still OK to drive in the meantime with the pump not active?
Thanks.
Edited by Grant, 16 August 2010 - 21:24.
#2 Tech1e
Tech1e
    CupraLoon
  • Honorary
  • PipPipPipPipPipPipPipPip
  • 35,856 posts
  • Car:Fabia Saloon 20vt, Citroen Motor Caravan
Posted 16 August 2010 - 21:25
Yeah as long as you can physically move it lol
#3 grr666
grr666
    Addict
  • New Member
  • 8,146 posts
Posted 16 August 2010 - 21:32
It'll be a pig to steer at low speeds. Especially doing manouvres and parking.
I ran a golf GTI round without power steering for a few months.
I'd rather not do it again that's for sure. Once properly moving it won't be
as bad and I actually preferred it at motorway speeds, the car felt more stable.
#4 Grant
Grant
    Briskodian
  • Members
  • PipPipPip
  • 262 posts
Posted 16 August 2010 - 21:54
Cheers guys :yes:
#5 DRJ
DRJ
    Briskodian
  • Members
  • PipPipPipPipPip
  • 3,158 posts
  • Car:(ex Fabia vRS SE #731) now Qashqai
Posted 17 August 2010 - 18:44
I wouldn't - when my rack failed it was VERY heavy - I only just managed to drive the half mile to the nearest Skoda garage...
#6 TriggerFish
TriggerFish
    Enthusiastically miserable
  • Members
  • PipPipPipPipPip
  • 4,725 posts
Posted 17 August 2010 - 18:49
When mine 'failed' it was fine on A roads and generally higher speeds, actually felt better, as Gary said, less twitchy. At low speeds though it came stuck at mini roundabouts, and larger ones had to be taken quite slowly, parking etc was a nightmare!
#7 andrew-ralston
andrew-ralston
    Member
  • Members
  • PipPipPip
  • 152 posts
  • Car:1995 S1 106 Rallye, 2006 Fabia vRS & Building S1 Rallye 16v Track Car ;-)
Posted 17 August 2010 - 21:36
I own a S1 106 Rallye drive it everyday and it hasnt got power steering it isnt that bad! but power steering racks are much heavier!
i have a friend who has a 106 GTi which the power steering failed... he was driving home on some back road and came to a corner and the power steering kicked back into life and he found himself on the verge and all over the road!!
but this might just be a French thing!
Edited by andrew-ralston, 17 August 2010 - 21:37.
#8 Thirdtimeluck
Thirdtimeluck
    Briskodian
  • Members
  • PipPipPipPipPip
  • 1,821 posts
Posted 17 August 2010 - 22:03
ooh la la! :D
#9 matt1chelski
matt1chelski
    Briskodian
  • Members
  • 11,149 posts
  • Car:Skoda Octavia vRS
Posted 18 August 2010 - 10:59
Think how heavy a great big diesel lump is over the front wheels tho! Lol, mines in the garage at the moment, same problem. I drove it to work, was nice once up to speed. As said, slower speeds are a little tricky :-/
Matt
#10 AndyPandy
AndyPandy
    Briskodian
  • Members
  • PipPipPip
  • 451 posts
Posted 19 August 2010 - 17:06
Thanks.
You would not be covered by your Insurance Company, and could be prosecuted by the Police if stopped ,if they found out !!
#11 andrew-ralston
andrew-ralston
    Member
  • Members
  • PipPipPip
  • 152 posts
Posted 19 August 2010 - 17:22
Matt
haha i actually thought about it i had to push my mates Type-R when its battery died and trying to move the powersteering rack without powersteering is mental!!
#12 DRJ
DRJ
    Briskodian
  • Members
  • PipPipPipPipPip
  • 3,158 posts
Posted 19 August 2010 - 17:49
My thoughts entirely when it was first mentioned - but I didn't want to be the first to raise it!
#13 matt1chelski
matt1chelski
    Briskodian
  • Members
  • 11,149 posts
Posted 19 August 2010 - 19:50
"it was working fine when i was driving officer" :rofl:
#14 Grant
Grant
    Briskodian
  • Members
  • PipPipPip
  • 262 posts
Posted 24 August 2010 - 20:30
Quick Update,
I checked the connectors around the starter motor as suggested and two of the cables were broken. I repaired these and are now sound. I also discovered that the pump was covered in foam and a plastic case which was soaking in water. I guess this is the cause of the problem, that the pump's electrics are soaked through and have become faulty. I cleaned it up and dried it best I could. I also removed the steering sensor (previously replaced 2 years ago) and cleaned it and gave it a squirt of wd40, possibly not the best thing to do? Over the weekend it has worked fine a couple of times, but not worked since Monday morning now.
Just done another vagcom Scan and got these faults
00816 - Power Steering Sensor (G250)
00817 - ??
01290 - ??
I've cleared these off and will check again when I get to work.
I presume this would mean that the pump is completely gone now. Can anyone advise? Reading the Haynes manual it seems a fairly straight forward job to change. I've also read somewhere that there is/was two different makes of pump, as far as I can tell (its written on the filler cap) mines a TRW. Are these interchangeable, or is there been an updated revised model. I'd like to get this fixed as soon as possible for the convenience, and the possible legal side of things.
Lastly how much fluid does the PAS system need for a full drain/refill?
Thanks for reading.
#15 Wynnie
Wynnie
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 30 January 2011 - 16:20
Quick Update,
00817 - ??
01290 - ??
Thanks for reading.
Did replacing your pump fix this for you? I have exactly the same issue.
#16 Waky
Waky
    Member
  • Members
  • PipPipPip
  • 213 posts
  • Car:An 'Elegant' Fabia...
Posted 30 January 2011 - 17:48
I've driven mine for 5 months with no power steering and no abs, it's lowered around 70 with 205 profile tyres, yes it is a bit of a pain to park but I don't mind, i would like itfixedthough lol... Luckily after 4 months of driving the abs turned out to be a fuse, let's hope my steering failure is the angle sensor :)
#17 Ray_Green
Ray_Green
    Briskodian
  • Members
  • PipPipPipPip
  • 709 posts
  • Car:Ex Yeti Owner, Now Kia Ceed 4 SW 126 BHP
Posted 06 February 2012 - 17:15
The Army never told me that. It used to take 2 of us the get an ANTAR (Tank Transporter) around the corner without power steering :(
Edited by Ray_Green, 06 February 2012 - 17:16.
