1.9 TDI does not ignite
Recommended Posts
Hello everyone,
I have a 1.9 TDI (2006) with ignition problems.
Description: I have realised that on the mornings when the car is "cold" it will turn on normally but, after 15 to 20 minutes of driving, it wont turn on again. I have to wait aroud 30 minutes so I can turn it on again. When this happens the ASR light always turns on; after my 30 minutes wait time, the light turns off and i can normally ignite the car.
My car has been in the shop for 10 days and they cant find the problem.
The scanner gives the fault codes 01314 and 18009. After doing some research in several webpages, seems that no one has the code 18009. The most accurate to the description the scanner gave is the 18010( I read them at ross tech), the difference is that the scanner descroption was "high voltaje".
They have test almost everypart of the car just in case it is not the computer(Engine Control Module) as code 01314 states. I have been trying to borrow a computer to try it on my car before buying a new one just in case it is not the computer without any luck.
One week before all this happened i had the a/c fixed, they remove all the section where the radio and a/c is to do this however, I alrady made the shop check all the wires around that section, they are all fine.
I really dont know what is going on with my car. Would anyone have any clue?
By the way i have been using a shop that only fixes skoda but is not the dealer shop. They dealer shop here in my country is B-A-D.
Link to comment
Share on other sites
18009 is Relay for supply voltage terminal 30 (J317) implausible signal.
Does the fault come back after it is cleared?
The relay is in position B4 on the onboard power supply control unit. Check that the plugs on the control unit are seated correctly and none of the wires has been pulled out of the connector.
Link to comment
First of all thanks for your help rwbaldwin.
As a background, around 6 days ago in a different shop, they found 7 pins loose on the steering column switch. I took it to my brother(He works with electronics) so he could weld the pins and test the piece with a osciloscope. The problem was not solved.
The relay on the onboard power supply contro unit is working just fine. They also checked all the fuses and relays on the electric box, they are fine. I am going to take it to my brother so he can test it again, just in case.
The fault codes reappear if you clear them.
Anyone has any other idea?
Edited by Mavv
Link to comment
If the relay itself is really OK, then it could be something inside the OBPSC or the steering column control unit or it could be the wiring between the units.
View measuring block 3.1 of the Steering Column Electronics Control unit to check the ignition switch. The digits will change as you move through the positions.
Link to comment
Ok i will try that on monday, thank you very much for you help rwbaldwin.
Another thing that i have realised is that not only the asr off light is on when you cannot start the car but also the electrical fan(not sure if this is the actual technical name, the fan that is close to the radiator) does not turn of for several minutes after closing the switch. Before i got the car into the shop it did not stop at all, or that is what I think because when i try to turn it on the battery was dead.
Thanks again.
Link to comment
  • 2 months later...
Did you get this fixed?
I have the same problem with my 05 1.9Td, have vcds and it comes up with intermittent ECU connection, once it starts goes no problem but will only start 1 in 20 times, when it isn;'t going to start the glow plug lights don't come on and ASR button is illuminated and the ASR warning light stays on, car will just crank, also fan will wind up and down if you leave the ignition to on for long enough, think is an ignition power switching relay supplying the ECU but am wondering which relay that might be!
If you found it was a relay which one was it?
Link to comment
  • 2 years later...
Very similar problem to my octavia 04. 1.9 tdi pd.  When the car starts it runs well. But it starts just 1 in 15-20 times. ASR/esp button is illuminated and the ASR warning light stays on. The hotter weather - less possibility to start. Yesterday was +29, couldn't start my car at all. Today just +15 the car starts from the first attempt.
Link to comment
If you have no luck trying the above the usual causes of hot start failures are either a dying battery or starter motor as the starter has to turn over at a certain RPM when hot before the injectors will provide fuel. this is a safety related thing apparently but is switched off when the engine is cold
Link to comment
Battery is fine, I don't think is a starter motor, because sometimes the car doesn't start when engine is cold. When ignition on I know if I start my car or not: if ASR/ESP light on I will not start my car, if ASR/ESP light off It starts easily.
Link to comment
  • 6 months later...
 3 months passed and my car still has the problem. Has anyone got any clue where is the problem. One thing was not mentioned here that VAG-COM can't connect to car's computer when there is ASR light on.
The car became almost unuseable because you can't even use it for shopping.
Link to comment
When I can start my car I have done scan. Results are these: Any clue where to look for fault?
Friday,28,March,2014,10:44:04:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBCS21Z448009713   Mileage: 229540km/142629miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 1010
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 1010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Sporadic communication error 1000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 AG    HW: 028 101 165 8
   Component: R4 1,9L EDC 0000SG  5897
   Revision: 12345678    Serial number: SKZ7Z0D2465441
   Coding: 0000071
   Shop #: WSC 73430 000 00000
   VCID: 68D5A6795B68FA9
2 Faults Found:
18009 - Relay for Supply Voltage Terminal 30 (J317)
            P1601 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    RPM: 0 /min
                    Torque: -98.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.08 V
                    Bin. Bits: 00000000
                    Bin. Bits:        0
                    (no units): 0.0
17057 - Cylinder 3 Glow Plug Circuit (Q12)
            P0673 - 000 - Electrical Fault - Intermittent
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 96.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.16 V
                    Bin. Bits: 11000100
                    Temperature: 8.1°C
                    Bin. Bits: 00110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 N
   Component: ASR FRONT MK70      0103
   Coding: 0017025
   Shop #: WSC 73430 790 00000
   VCID: 3D7B272D646A8F1
1 Fault Found:
01314 - Engine Control Module
            004 - No Signal/Communication - Intermittent
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1Z0 820 047
   Component: Climatic PQ35   004 0201
   Shop #: WSC 00000 000 00000
   VCID: F0E54E19E3B8B29
1 Fault Found:
00457 - Control Module for Network (J519)
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
   Component: Bordnetz-SG 1.0 H29 0701
   Revision: 00029000    Serial number: 00000001192849
   Coding: 00880F020004140000110D000000000000
   VCID: 377735054656A51
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 00000
10 Faults Found:
00059 - Terminal 30 for Interior Lighting
            012 - Electrical Fault in Circuit
01336 - Data Bus for Comfort System
            014 - Defective - Intermittent
02071 - Local Databus
01800 - Light Switch (E1)
            008 - Implausible Signal - Intermittent
00926 - Terminal 30
            011 - Open Circuit - Intermittent
00918 - Terminal 31
01516 - Terminal 30; Left
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
            009 - Open or Short to Ground - Intermittent
00834 - Signal for Activation of Heated Rear Window
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 G    HW: 1K0 909 605 G
   Component: 09 AIRBAG VW8   023 0600
   Revision: 06023000    Serial number: 0037VD046EZR
   Coding: 0012345
   VCID: 30650E19A338729
No fault code found.
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000012
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1Z0 920 910 D
   Component: KOMBIINSTRUMENT VD4 3556
   Coding: 0003401
   Shop #: WSC 00001 210 01865
   VCID: 346D020957204E9
2 Faults Found:
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 210010441508AA
   Coding: 3D3F0340071303
   VCID: 2757E54596F6351
10 Faults Found:
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 184
                    Reset counter: 180
                    Mileage: 229211 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:08:59
00466 - Control Module for Steering Column Electronics (J527)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 163
                    Mileage: 229352 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:27:48
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 217
                    Reset counter: 170
                    Mileage: 229352 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:28:02
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 216
                    Reset counter: 170
                    Mileage: 229352 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:28:03
00474 - Control Module for Immobilizer
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 162
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:38:13
01316 - ABS Control Module
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 163
                    Mileage: 229389 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:15:05
01333 - Door Control Module; Rear Left (J388)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 163
                    Mileage: 229389 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:26:19
01334 - Door Control Module; Rear Right (J389)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 163
                    Mileage: 229389 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:26:19
01320 - Control Module for Climatronic (J255)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 163
                    Mileage: 229389 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:12:55
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 178
                    Mileage: 229528 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:06:07
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO                3556
Address 42: Door Elect, Driver        Labels: None
   Part No: 1T5 959 701 %
   Component: Tuervteuerg`raet 0< 0146
   Shop #: WSC 07894 788 00000
   VCID: 1E39C0A1C9ACF49
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
            001 - Upper Limit Exceeded - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 F
   Component: EPS_ZFLS Kl.2       1301
   VCID: 2F670D65BE066D1
3 Faults Found:
             Freeze Frame:
                    Mileage: 9200 km
                    Temperature: 10.0°C
                    Voltage: 8.30 V
                    Voltage: 10.60 V
00668 - Supply Voltage Terminal 30
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Mileage: 9320 km
                    Temperature: 14.0°C
                    Voltage: 8.30 V
                    Voltage: 10.20 V
00446 - Function Limitation due to Under-Voltage
             Freeze Frame:
                    Mileage: 9400 km
                    Temperature: 14.0°C
                    Voltage: 7.80 V
                    Voltage: 7.60 V
Address 46: Central Conv.        Labels: None
   VCID: 55AB9F8DBC1A771
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Component: Tuersteuergeraet 09 0146
   Coding: 0000116
   VCID: F5EB7F0D9CDA971
1 Fault Found:
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 A    HW: 01. 01. 03
   Component: Radio FO3           0008
   Coding: 0000402
   VCID: 2C5D1A698F10169
3 Faults Found:
00856 - Radio Antenna
            007 - Short to Ground
00849 - S-contact at Ignition/Starter Switch (D)
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 B
   Component: Tuersteuergeraet 06 0205
   Coding: 0000048
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 B
   Coding: 0000048
End   ---------------------------------------------------------------------
Link to comment
I think my first port of call would be the battery, is it still on original? if so a new battery might solve most of those.
Sorry, should have read back over the full thread before posting. maybe water has got into the electrics somewhere?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
